Autodesk CFD FSI using ANSYS Workbench
I am currently attempting to utilize this software's capabilities to write out pressure results to an FEA deck. I noticed that while the program does work with ANSYS, it writes the files to ADPL formats, which are rather antiquated. Workbench itself doesn't natively, at least on the surface, use these file formats. Within workbench, I attempted to write the files out to the formats needed (to read them back in at a later time), which worked, but CFD can't properly create the FEA decks even with the correct file formats. The main question is whether or not Autodesk CFD can even work with ANSYS workbench and if so, what are the proper steps to setting it up? I did follow the instructions given on how to output files for FSI, but it is possible I am doing something wrong. However, without knowing whether or not it is even possible, I don't want to keep troubleshooting. Thanks!
