Does Autodesk CFD have an equivalent to the "wall lift-off in viscous units," "wall lift-off (in length units)", and "dimensionless distance to cell center" that COMSOL provides? If so, how do I check them?
I use Autodesk CFD and have been reading up on turbulence models and mesh sizing in general. I came across an article by COMSOL where they mention checking the "wall lift-off in viscous units" during their analysis. If they are below a value (11.06), this indicates that the mesh along the walls of a model is likely fine enough. They also recommend checking the "wall lift-off (in length units)" and the "dimensionless distance to cell center."
Having these values to check seems really helpful for validating model setup. It's more empirical and less "by feel" than most recommendations I've seen so far.
Here is the original article: http://www.comsol.com/blogs/which-turbulence-model-should-choose-cfd-application/
Thank you,
Eric
