Assigning temperature to boundary conditions volumetric flow rate
milos28HR3
milos28HR3
I'm trying to simulate an outlet that is discharging hot air into a larger stream of air represented by an external geometry with a velocity and a pressure boundary condition. I know the temperature and velocity of the unidirectional bulk stream of the external geometry. I also know the geometry of the outlet that is inside of the external geometry (represented by a suppressed solid) , the volumetric flow rate coming out of that outlet, and the temperature of the air discharged from the outlet and injected into the external volume stream. I'm trying to visualize the mixing of the two air streams and the resulting temperature gradient downstream of the outlet.
Is there a way to assign temperature to the air stream leaving the outlet? I understand I can assign temperature and heat flux to the outlet surface. But that looks more like the surface is radiating heat (with some convection) into external volume, I'm looking to find out what happens when I "inject" the heat together with the outlet discharge into external volume. Does anyone know if this is possible to do in Autodesk CFD? If so, what would be the appropriate method of setting the boundary conditions?
marwan_azzam
Hi @milos28HR3 ,
If you want to introduce hot air into another air volume then set a flow rate (or velocity) and temperature boundary conditions to the inlet surface. It's as simple as that.
Marwan
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
