Hello There,
I am a new user of Autodesk CFD. I installed the 2019 version (19.2) using the browser installation method and an academic license, and it runs just fine showing me the Start & Learn Window. However, when I try to load any type of geometry file to start a new model and Design Study from [New>Model>Browse], naming the Design Study then hitting Create, there is some loading time then it eventually gives me the following error message (screenshot attached):
Assertion Failed
File:
C:\Jekins\jobs\GLviewAPl3_Distribution\workspace\CeeVizFramework\dev\LibRender\cvfShaderProgram.cpp
Line: 135
Expression: ShaderProgram::supportedOpenGL(oglContext)
Can you please give me any hints about this error?
Thanks.
I get the same assertion. Any help?
in my case I get this on first opening CFD right after the splash screen and "trail license" dialog. I opened it from Fusion360 simplify workspace.
my system is VirtualBox6.1.2 running Windows10 on top of MacOS on a 8 core, 32GB RAM machine.
I am watching this error when I try importing any geometry files direct from CFD. If you open your model from Inventor you will not have this problem.
