air particle disappears + can't see the wing tip vortex
Hi, I'm working on a high school project, and I came up with an idea to reduce wingtip vortex.
I made a .step file for my own designed wingtip and ran it on Autodesk CFD, but things doesn't seem to be right.
First of all, I can't see any wingtip vortex forming behind the wing, which is supposed to be happening in all wings. like the picture above.
f18-lex-cfd1
But air flow around my wing just goes over the wing and goes straight after passing the wing.
Second, I have something like a pipe on my wing, and I wanted the air coming from the front of the wing to pass through that pipe and be emitted on the end of the wing.
But it looks like this.
66065190_339089993679298_3678287533633961984_n.png67127268_318675579037368_3878397640571879424_n.png
As you see in the picture the air particle sort of like gets stuck in the pipe and can't come out.
Why is this happening? And how can I solve it?
Please keep in mind that I'm completely new on Autodesk CFD. Might have missed some easy simple stuffs.
Thanks, and I'll be waiting for y'all help
Oh, btw I uploaded my .step file's dropbox link in reply. Plzzz somebody help. My deadline is close 😞
- CAD file contains very tiny edge length (below 0.5mm) is it normal?
- Within the hollow region, sharp angle will be difficult to mesh
Wall layers, turbulence model, y+ value, and mesh refinement regions are critical parameters to be finely tuned. This is not a single shot analysis.
I realize it's been a month now, I hope you have succeeded
Hi there!
Thanks for your help 🙂
Well, my project ended a few months ago. Just improvised in front of my teachers - they don't seem to be understanding these aerodynamics as well.
Anyway, it's surprising that you've actually made it work! I wonder how you managed to do that.. What was my problem?
Oh, and one more thing. Was the air particle able to enter the passage I made in the wing? Can't see clearly on your picture.
Thanks for your help!
