A Simple Hotbox Simulation
bcallie
bcallie
I'm very new to Autodesk CFD and CFD in general so please bear with me. I'm trying to simulate a hotbox I've designed to determine the heat flow from one side of the brick's surface to the other. The brick sits in the middle of the insulated box, dividing the interior into two sections. On one side I'm using an extruder from a 3D printer as the heat source, while on the other, ice cold water is running through tubes to regulate the heat transfer. I've looked at tutorials online and similar forum questions in order to set up my simulation correctly. However, each time I run the solution an error occurs.
Any chance someone can help me determine the setup required in order to run a successful simulation? (ELI5)
Jon.Wilde
This should be simple enough to do 🙂
Do you have a support file (CFZ) that you could share with the forum?
Jon
bcallie
Hi Jon,
Unfortunately I can't share the file on the forum. Can I email it to you?
- bcallie
Jon.Wilde
Hi bcallie,
I would say no, not really. I don't want to risk publishing anything accidentally.
If you have a subscription with us, we could move to a 1:1 case?
If not, then could you share some images or a sketch of your setup? That might be enough.
Jon
