Good morning everybody, I am having problems with the model I am working on. It is a model made with rhinoceros on a specific urban environment, specifically a university campus. The main idea was to make a wind tunnel simulation in a model without trees, only with the buildings that make up the campus. Once this was successfully done, the idea was to add trees to the same model and run the simulation again to compare results, creating different scenarios.
When adding the trees to the simulation, everything works correctly until the simulation starts running and after 5 minutes I get this message. "A material device is not adequately defined relative to the neighboring fluid parts".
Each element in the simulation has its own material, in this case the trees, have assigned certain resistances.
When assigning this type of material (resistance) I have not applied it individually to each tree one by one but I have created a series of rules, I have selected all the trees of a type, I have applied a resistance and I have selected the normal surface to the flow in a tree and it has been applied to the rest. I don't know if this is the problem and I should apply the resistance one by one, which seems crazy to me since there are so many trees. I try in another model that I have smaller, there are only 3 trees and everything works correctly following the same steps explained.
If someone could help me, it would be of great help.
Thank you so much in advance
