社区
CAE/CAM综合讨论区
欢迎访问欧特克CAE/CAM论坛!分享知识,发帖提问,浏览CAE/CAM热帖。
取消
显示结果
显示  仅  | 搜索替代
您的意思是:
等高螺旋策略没有2D转角
3 条回复3
已解决
回复
1 条消息(共 4 条)
380426370
2076 次查看, 3 条回复
等高螺旋策略没有2D转角
螺旋有3D确没有2D转角这样算是什么奇葩?没有2D螺旋转角开粗嘎嘎响,经历了十多年工程师就没发现这个问题?还是说这就是想改?
3 条回复3
2 条消息(共 4 条)
Thank you very much. I fully understand that both options of Spiral and  2D filleted corners are important for high speed machining of the constant Z strategy, Unfortunately the spiral constant z toolpath is always in 3D and so it cannot be smoothed by 2d arcs at corners as the current code implementation. We, developers, might need to reconsider this. That is, shall we first fit all constant z segments by arcs in 2d and create the spiral toolpath from the arc-fitted segments? Some more feedback and testing are still required before changing the code.
Jianhua Fan
3 条消息(共 4 条)
I opened the development/bug task https://jira.autodesk.com/browse/PMILL-19963 for Powermill developers  to have a further look. Thanks.
Jianhua Fan
4 条消息(共 4 条)
是的,高度螺旋加工没有这个2D转角到拐角的时候刀粒会挤崩,机床也受不了!希望能快点开发出来!!!
找不到想要的内容?向社区提问或分享您的知识。
到论坛发帖
