I am on the verge of buying 8 fairly high spec rack mount PC units that will be primarily used for running AutoCAD. Before I do this I thought I should look into the possibility of buying only 1 very very high spec PC (possibly 2 if one was not feasible) and using virtualization to run 8 different servers.
I dont know a great deal about Virtulization and was hoping someone on here could offer some advice. Is what I am talking about even possible? If so, would I need to specify 8 x recommended RAM? what Proccessor should I specify? How do graphics cards work in virtualization? do you need one per server?
I would be very greatful if somebody could offer some info on this, or at least point me in the right direction of some good resources.
many thanks,
Chris
Keep in mind that to stay compliant with your license agreement, this is only supported in a Citrix environment.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16785740&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16755552&linkID=9240617
http://www.youtube.com/results?search_query=%40autodesk%2C%20citrix
Why is it only supported with Citrix?
What about VMware? Hyper-V, Terminal Services, etc???
I can take a thin client without a hard drive and run 4 CAD sessions at the same time. It's called Jentu, http://jentu-networks.com/ or check them out on facebook. https://www.facebook.com/JentuNetworks
If you'd like, I can have the admin remove your post.
No thanks. I do not want the post removed and I stand by my comments. I've testing with more resource intensive applications and the results were amazing. I said that "I can" and if they audit me then they will find nothing because it is a concept.
The base image is streamed from the server and is a bare metal on a diskless desktop/laptop. I would think that if this was possible then AutoCAD would just jump all over it. They have partnerships with multiple hardware vendors. Are the CEO's friends and try to lock down this market? What type of internal agreements do you have in place?
I could sell 1000's of licenses in a flash. I can strictly follow license agreements if CAD if you will let me. Imagine the possibilities if you can create a better experience for the users and deliver lightening fast response with infinite processing / rendering capabilities.
I have two clients that are willing to give it a try. I also noticed that Jentu was approved for use in government installations. You should check it out and get your Dev people to certify the product so I can afford to buy it and sell it as an MSP offering. The CAD Private Cloud, it's catchy.
larry@quantus.biz
larry@subpico.com
I thought Autodesk loosened their licensing terms with regard to virtualization.
Even if they haven't they'll likely look the other way or kindly grant an exception given the following....
Every year they have presentations on "Virtualization" at AU. Not all are Citrix based.
Companies like Advance 2000 have been doing this for several years with Autodesk's full knowledge. In fact, I believe some of A2K's staff use to work for Autodesk.
Autodesk has a virtualization partner (http://www.imscadglobal.com/virtualisation-CAD.php) and many of the solutions they offer are NOT Citrix based.
