I know that you can use setvar to get a list of system variables but when i do it the list does not go by alphabetical order so my list goes all over the place. Basically what i do is type in setvar, hit the "?" symbol, then hit the "*" symbol. Then i copy everything into notepad after hitting enter about twenty times. Is there a better way to go about this? I would like an ordered list of all of the system variables hopefully going in alphabetical order
Solved by jggerth1. Go to Solution.
Expresstools menu, system Variable Editor. Pick the Saveall button on the dialog, and save the resulting file where you can find it. The extension will be .SVF, but it's nothing more than a plain text file you can open with any ascii editor.
Tip:
Set QAFLAGS to 2 prior to listing the setvars and it will not create a pause requiring an enter, the list will scroll to the bottom without stopping.
Thanks for the info. I do like the express tools cause it tells you what the different variables are for without having to look it up but i do appreciate the help.
