Dear friends
I have problem in all my sheets it doesn't take that effects which have I made in Xref , for example, I made layer freeze and I still showing these layer when I opening all my sheet's, that's all if anyone can solve I'll be thanks so much
Solved by imadHabash. Go to Solution.
>> I made layer freeze and I still showing these layer when I opening all my sheet's,<<
VISRETAIN system variable can help if you change it to (0) in your sheets.and you have to change it in every sheet to get the result .
Command: VISRETAIN
Enter new value for VISRETAIN <0>:
