Long story short in the Geolocation Ribbon needs to be switched to full without focus on several dozen machines.
There is also an existing 3rd party software that needs to be manually attached for a certain percentage of the user base and a few other pieces don't always end up attached to the main CUI when users are switched and I do not want to add these partials to the Enterprise CUI.
The simple solution is for me is to mass copy and replace the C3D.cuix file on all the machines prior to there setup.
Is there any lag time, cost with having unresolved Partial CUI's?
I've been told in the past that missing support paths on the "C" drive have a negligible time loss but is it the same for CUI files?
Solved by TravisNave. Go to Solution.
Solved by pendean. Go to Solution.
