Hi There C
I haD a question on naming sheet with the Discipline Designators. If i have a project starting with A-101, next will be A-102...can the next page be AE-103 ?
follow by A-104?
Is this possible on projects?
I will be glade on having a respond on this issue i am having.
Thanks Good day!
See if this webpage addresses what you are looking for https://www.usbr.gov/foia/Vol%20III/NCS-CAD_Layer_Guidelines.pdf and http://www.caddee.com/layerlist.html
I work with Electrical projects and most of our project have only one Discipline Designator on each sheet.
If i start with a E-101....can the next sheet be ET-102 follow by E-103 ?
this is my issue!
having a sheet with 2discipline designators follow by a sheet with one discipline designator.
Thanks . I have contact, the National CAD Standard Steering Committe to assist with resolution.
They stated that each discipline grouping would require its own set of numbers as follows:
E-101
E-102
E-103
ET-101
ET-102
ET-103
If you then add E-104 it would fall right after E-103 and before ET-101.
E-101
E-102
E-103
ET-101
ET-102
ET-103
I agree.
