DanielLench_
9 min 59 sec read
This widget could not be displayed.
 Intro
    Managing a group of people, or in this case, machines used by people, undoubtedly comes with challenges unique to the type of work being performed. Consistency with standards and supporting documents foster an environment that allows for greater focus to be paid to the quality and correctness of the work. Providing a foundation for production within the CAD environment reduces rework and enhances the user’s experience. These ideas, when supported and enforced, provide faster onboarding, a better product, a stable environment, and ad-hoc teams in an agile workforce.
     Bringing this vision of a perfect environment within one office with few users is viable. Applying the same vision across a dispersed workforce in multiple locations with regional specifics is a moonshot, to say the least. In the imperfect setting, perfection comes a little differently. Both scenarios are always evolving, but with different milestones and goals. Methods that work in a small office will break an enterprise. Foundations in the enterprise are not cost-efficient in the small business.
     I submit, for your consideration, a detailed account of the means and methods that I have discovered and put in place over the last 20 years in CAD management roles. This series of articles will cover a vast assortment of topics. None of this could have been realized without the assistance and generosity of countless people and the companies that have supported me as non-billable knowing that the benefits outweigh the cost. @ToddRogers-WPM has been an invaluable sounding board over the years, and I’m honored to call him a friend and coworker. Angel Espinoza, the Bartel bros., Lynn Allen, James Maeding, and all the engineers and coworkers have influenced these decisions. And a thank you to the people that welcomed me to the world of civil engineering, Kelly and Marty Aguerre.
The support folder, acad.lsp, and acaddoc.lsp
     So we begin, with the installation and first run setup procedure of AutoCAD, Civil3D, or the like, on your shiny new computer or the new version year. I try to leave the installation as unmolested as possible, so there will be no profile, pgp, or cui edits. I will cover the way I integrate, and supercharge a new installation with three easy steps.
  1. Set the support folder path to a networked location and move that folder to the top of the list.
  2. Set the Pipe Catalog using the command SETNETWORKCATALOG to the networked location.
  3. Restart CAD TWICE.
Done! But now let us talk about how it is actually done, because there is a lot going on under the hood.
Really quick about LSP:
  • LSP or LISP files contain commands in a scripting program style that can accomplish almost anything special.
  • LISP is a very mature language and the original way of customizing AutoCAD behavior.
  • My method of using LSP in enforcing standards follows the idea that someone with limited programming experience should be able to understand and modify many of the files. This means that many of the LSP files I create could be greatly shortened but are intentionally repetitive for ease of reading. Some special things will require more advanced knowledge of LISP or external consulting.
     Opening the options dialogue box and the files tab will get you to where we begin the journey. At the top of mine, you will see I have S:\ACAD\Support, along with all the standard paths from the installation. I’ve added the path and moved it to the top, so the program looks there first. I have not edited or removed anything else in the options dialog.
     The support folders are locations where the program looks to find various files that make different parts of the program work. It also can contain some special files that control what gets loaded either once at program start-up (acad.lsp) or when opening each file (acaddoc.lsp).
     I start with a folder stored on the server named ACAD. This folder lives in a permission-protected location with additional and more restrictive permission set on a subfolder that will be discussed later. The other folders house files that will be discussed later in the series.
     The support folder is the one we are interested in today. Inside the support folder, I have placed linetypes, shp, and shx files. As well as some dll, ini, and other files from Civil3D versions where they were not broken. An example of a broken item, where placing the dll in a common location is beneficial, is the version of Civil3D where creating a data shortcut of pipes and structures did not respect the styles from the source drawing. I placed the C3DPipeNetworkRules.dll file in our support folder and the company was immune to bad behavior until an update was produced. Another instance was the 2 foot sumps in structures bug. IYKYK.
     But all of this is just gravy when you use the acad.lsp file to setup all your company standards. In the support folder lives my acad.lsp and acaddoc.lsp. Since they are in the first folder in the support folders list, they get loaded anytime the program looks for them.
     The contents of my acad.lsp set all the other support paths but only if they haven’t already been set. The IF statement checks the environment variable, and the variables $temp1 and $temp2 combine the output and apply the environment variable.
     For example:
  • Check if the path for the environment variable “PrinterConfigDir” is "S:\\ACAD\\Plotters"
  • If it is, do nothing and go to the next line
  • If it isn’t, set it to "S:\\ACAD\\Plotters"
Having the IF statement improves performance, because the program doesn’t change anything if it doesn’t need to.
(if (/=(getenv (setq $temp1 "PrinterConfigDir"))(setq $temp2 "S:\\ACAD\\Plotters"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "PrinterDescDir"))(setq $temp2 "S:\\ACAD\\Plotters"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "PrinterStyleSheetDir"))(setq $temp2 "S:\\ACAD\\Plotters"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "TemplatePath"))(setq $temp2 "S:\\ACAD\\Template\\"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "SheetSetTemplatePath"))(setq $temp2 "S:\\ACAD\\Template\\"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "QnewTemplate"))(setq $temp2 "S:\\ACAD\\Template\\CORE-Civil.dwt"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "AlternativePageSetUpsTemplate"))(setq $temp2 "S:\\ACAD\\Template\\CORE-Civil.dwt"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "ToolPalettePath"))(setq $temp2 "S:\\ACAD\\Toolpalette\\Tools\\Palettes\\;S:\\ACAD\\Toolpalette\\Core\\Palettes\\;C:\\ProgramData\\Autodesk\\ApplicationPlugins\\groundforce.bundle\\Contents\\Resources\\ToolPalette\\en-US"))(command "*_TOOLPALETTEPATH" "S:\\ACAD\\Toolpalette\\Tools\\Palettes\\;S:\\ACAD\\Toolpalette\\Core\\Palettes\\;C:\\ProgramData\\Autodesk\\ApplicationPlugins\\groundforce.bundle\\Contents\\Resources\\ToolPalette\\en-US"))
(if (/=(getenv (setq $temp1 "PlotSpoolerDirectory"))(setq $temp2 "C:\\0plot"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "Temp"))(setq $temp2 "C:\\0scratch"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "TMP"))(setq $temp2 "C:\\0scratch"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "TempDirectory"))(setq $temp2 "C:\\0scratch"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "SaveFilePath"))(setq $temp2 "C:\\0scratch"))(setenv $temp1 $temp2))
(if (/=(getvar (setq $temp1 "Logfilepath"))(setq $temp2 "C:\\0scratch"))(setvar $temp1 $temp2))
(if (/=(getenv (setq $temp1 "XLOADPATH"))(setq $temp2 "C:\\0scratch"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "MoveBak"))(setq $temp2 "C:\\0scratch"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "CmdHistLines"))(setq $temp2 "2048"))(setenv $temp1 $temp2))
(if (/=(getenv (setq $temp1 "DCTMAIN"))(setq $temp2 "ENU"))(setenv $temp1 $temp2))
     Now that all the plotters, tool palette, template, and temporary save paths have been set, we can look at some more exciting things. I place system options in the acad.lsp, things that only need to run on startup. Drawing and session options in go in acaddoc.lsp, and get loaded or checked each time a file is opened. Inside the acaddoc.lsp, I load lsp files that are used in the tool palette or the command line as well as some that ensure the 0 layer is thawed and white and some that reset most, or all, the system variables in autocad. That last feature is super powerful when you have a large workforce and don’t want them using a specific command or want to ensure things like “filedia” is always correct. We can use the acaddoc.lsp to rollout an automatic purge or audit on every file opened or change a variable like “USERI1” for some special functions. You can see that I comment out some lines, because I don’t want those to run unless there is a special need.
;;;;;;;;;;;;;Core Tool Palette Dependencies;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(load "S:\\ACAD\\Support\\Applications\\CC.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\COUNTPARK.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\FreezeXrefLayer.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\GoogleMapViewinCAD.lsp" "Failed to Load")
;(load "S:\\ACAD\\Support\\Applications\\INTERPOL.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\LABELPARK.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\LABELPKCURVE.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\LYRTODEMO.LSP" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\LYRTODEMOPHASETXT.LSP" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\REVCLOUDWPM.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\SQFT.lsp" "Failed to Load")
;;;;;;;;;;;;;;CORE LOADER;;;;;;;;;;;;;;;
(load "S:\\ACAD\\Support\\Applications\\CORECHECKER.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\COREDETAIL.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\COREFONTS.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\CORELAYERS.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\CORELT.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\CUSTOMLT.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\CORESHORTCUTS.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\COREAPPS.lsp" "Failed to Load")
(load "S:\\ACAD\\Support\\Applications\\HINT.lsp" "Failed to Load")
;;(load "S:\\Acad2020\\Infra\\ctp-programs")
;;;;;;;;;;;;;;System Variables;;;;;;;;;;
(load "S:\\ACAD\\Support\\Applications\\CORESysvar.lsp" "Failed to Load")
;(load "S:\\ACAD\\Support\\Applications\\Sysvar-RESET.lsp" "Failed to Load")
Goodies
     What you see is the backbone or root of the CORE standards in our company. These standards provide a unified environment so that everyone’s machine behaves the same. I have modified some standard keyboard shortcuts to provide better functionality but leave further customization to the user. I could enforce that the company uses a white paper background, or a 100 width crosshair, but people have opinions about that. Regional standards are supported in the tool palette and through more LISP files.
The custom keyboard shortcuts live in the CORESHORTCUTS.lsp file. They don’t require any more pgp file editing and they look like this:
(defun c:mm () (command"mleader") )
(defun c:rev () (command"reverse") )
(defun c:flp () (command"labelflip") )
(defun c:au () (command"audit" "y") )
(defun c:pe () (command"pedit" "m") )
(defun c:pp () (command"PLINE") )
(defun c:fr () (command"layfrz") )
(defun c:la () (command"-layer") )
(defun c:lp () (command"layer") )
(defun c:lo () (command"layoff") )
(defun c:loa () (command"layon") )
(defun c:qe () (command"qleader") )
(defun c:qa () (command"qlattach") )
(defun c:ee () (command"executetool") )
(defun c:t2m () (command"txt2mtxt") )
(defun c:da () (command"dimaligned") )
(defun c:de () (command"ddedit") )
(defun c:rb () (command"REBUILDSURFACE") )
(defun c:ie() (command"_AeccInsertFeatureElevPoint") )
(defun c:de() (command"_AeccDeleteFeatureElevPoint") )
(defun c:sl() (command"_ADDSURFACELABELS") )
(defun c:mb () (command"CONVERTLINEWORKTOMASKBLOCK") )
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;Standard Commands Load;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:fx () (command"audit" "y") (command"-purge" "r" "*" "n") (command"-purge" "a" "*" "n") (command"qsave") )
(defun c:fxs () (command"audit" "y") (command"-purge" "r" "*" "n") (command"-purge" "a" "*" "n") (command"qsave") (command"ltscale" "1") (command"dimtxt" "0.1") (command"msltscale" "1") (command"psltscale" "1") (command"dimscale" "1") )
(defun c:qp () (command"qpmode" "1") )
(defun c:qq () (command"qpmode" "0") )
(defun c:fcL () (command"audit" "y") (command"-purge" "r" "*" "n") (command"-purge" "a" "*" "n") (command"qsave") (command"close" "y") )
(defun c:fq () (command"audit" "y") (command"-purge" "r" "*" "n") (command"-purge" "a" "*" "n") (command"qsave") (command"quit" "y") )
(defun c:sa () (command"snapang") )
(defun c:cg () (command"cgslist") )
(defun c:i () (command"_ClassicInsert") )
(defun c:dn () (command"DIST") )
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;BETTER DISTANCE TOOL WITH SLOPE;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:di () (command"cgslist" "p") )
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;VOLUME CALCULATIONS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:rs () (command"REPORTSURFACEVOLUME") )
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;FEATURE LINES;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:fe () (command"_AeccQuickEditFeatureElevs") )
(defun c:fl () (command"_AeccDrawFeatureLine") )
(defun c:fc () (command"_AeccCreateFeatureLines") )
(defun c:fj () (command"_AeccJoinFeatures") )
(defun c:fi () (command"_AeccInsertFeaturePI") )
(defun c:fg () (command"_AeccSetFeatureGrade") )
(defun c:fre () (command"_AeccSetFeatureRefElev") )
(defun c:fb () (command"_AeccBreakFeatures") )
(defun c:fd () (command"_AeccDeleteFeaturePI") )
(defun c:fa () (command"_FeatureAddAsBreakline") )
I’ve even made a cute dialogue box that you can open by clicking my “HINT” tool in the tool palette.
     You may notice the two buttons below HINT, “CAD Help” and “CAD Standards”. The CAD Help button will start an email to our CAD helpdesk and open a support ticket. The CAD Standards button will open our company portal with examples and detailed instructions for file setup as well as plan production sheets.
Next time
     Next in the series, I will talk about the tool palette and how utilizing a networked and protected standard can bring the company closer, while acting like a portal to the CAD management team.
Thanks team!
Comments
@DanielLench_, thank you for sharing this amazing work! Really interesting standardization practices. Looking forward to the next articles! Btw, really curious about these tools in the tool palette and how to create them, nice!
@DanielLench_ thanks so much for sharing your knowledge about cad management. It is a topic with little information and requires many years of experience to build a validated and useful workflow. @Matheus-Lima thank you so much for bringing this post to my attention.
Hi Daniel,
We have been using BIM360 DOC's and now ACCDOC's(along with Desktop Connector) for our ACAD/Civil3D and Revit file storage/editing for the past couple of years. This year we embark on an "official" launch of our Company Standards, introducing these products as our "go to" file management tools. What are you thoughts on how we would replace your "networked location" with ACCDOC's? Before the Desktop Connector was upgraded to Version 16, we had everyone in the company using C:\ACCDocs\ for the "networked location" and that worked fairly well. But now, V16, has a path that is user specific(C:\Users\pjacobchuk\DC\ACCDocs\), making me feel like I need to resort to using %userprofile% in places like your lisp routines and the .arg file. Again, your thoughts. And thanks for a well written article. It helped confirm things we are already doing and offered new things to explore.
@pjacobchuk, this is an excellent question, given all the changes made in v16 of the Desktop Connector. I'll do some more digging and welcome others to comment about their local folder behavior when using Autodesk Docs with support/CORE files. I have implemented a robocopy script at login that mirrors support folders mentioned here to a local location.
This is to reduce common files requested over the network. I'm trying to position these support files in a way that prevents them from impacting bandwidth and allows offline work, such as on an airplane. I mirror anything that gets loaded when ACAD starts and before a drawing is open. Whatever project I'm working on, I copy the files needed. We aren't fully on Autodesk Docs in ACAD.
I agree that a more elegant method is possible, I've done it with dropbox in the past so Desktop Connector should be able to as well. We are using Panzura currently for replication across our offices.
@DanielLench_ Thanks for sharing this workflow. currently I have an ACAD (C3D) Server support folder that is write-protected. The support folder is then dynamically mirrored to each CAD Users C drive. This is working well to keep everyone mapped to the same settings while not worrying about network latency etc. I am updating my workflow to incorporate the ACAD.lsp and ACADDoc.lsp to include the path if statements in your method. This is working great for updates.
My question is: Every time I modify the ACADdoc.lsp the test users that are mapped to the file get the dialog box to choose always load, load once or do not load. My question when selecting always load it still come back with the next lsp modification. Can I make this not happen by adding it to all users APPLOAD STARTUP list or is there a better to automate this to accommodate future lisp changes more in the background and not require users to load this.
@jwylie2020 this sounds like a trusted paths issue. Try adding this as the first line of the acad.lsp file and replace s:\\acad\\... with the root location of the path in the dialog. Keep the three dots to indicate that ALL folders under the root are to be trusted. Add additional paths with semicolons in between, and don't forget to escape the backslashes.
(if (/= "s:\\acad\\...;%LOCALROOTPREFIX%\\support\\;%AECCCONTENT_DIR%\\data\\reports\\net" (Getvar "TRUSTEDPATHS"))(Setvar "TRUSTEDPATHS" "s:\\acad\\...;%LOCALROOTPREFIX%\\support\\;%AECCCONTENT_DIR%\\data\\reports\\net"))
Thanks! @DanielLench_ I updated my acad.lsp with the trused paths code above, made modifications and it is now working smoother.
My other question is that I was adding support folder paths for Blocks, Fonts, Hatch, Linetypes, Lisps, and Profiles to the Support File search Paths. Are you doing something similar to this? I thought perhaps IF statements could be used in the ACAD.lsp to add the paths to the support file search path.  I could not tell how you are mapping linetyps, fonts, etc.
@jwylie2020 I combine the linetypes into one CORE file for standard ones that, along with other linetypes live in the support folder. Profiles are not used because everything is in the Tool Palette or lsp. Blocks are in the tool palette and saved in a separate folder, not in the paths. Fonts live in the support folder. Hatches live in the support folder. I just get over the "clutter" and put everything in the Support folder. It's fine. Just order by type and name them in a manner that organizes them smartly by name.
@DanielLench_ That sounds good and what I suspected. I thought it was possible that Support File Search Path would find items in subfolders of the pathed support folder. I assume like the SETNETWORKCATALOG, Import C3D Survey User Settings needs to be done in the prospector. I also wondered if there This really simplifies onboarding and upgrades.
Thanks so much! I hope this helps others too.
@jwylie2020, I haven't found a way to set the network catalog automatically yet (and again do not want to rely on profiles), and we don't use the survey features here. Thank you for the great questions! Is everything working well now?
@DanielLench-WPM Yes, Its going well with testing. I am just down to making a few routines to drop in for settings that most users want but dont have to adhere to. This infrastructure should be simple enough nonCAD IT people can jump in and help with full installs. Thanks!
The new install protocol should be:
  • Install C3D, heck for updates
  • Map the support folder
  • Open Onboard Toolpalette
    • Hit a routine for setting most users want (but can change if they prefer)
    • Hit button to set pipe network catalog dialog path
    • Hit button to set pressure network catalog dialog path
  • Import C3D Survey User Settings
  • Restart CAD Twice
@DanielLench_  great article... and certainly great dialog from everyone! I want to make sure I understand something out of the gate. How are you setting the support folder path? Are you creating a deployment with that predefined? Are you pushing an OOTB install and going to each user and manually doing it? Are you using robocopy to do something else?  Thanks!
I have not timed it, but this does not sound accurate --> "Having the IF statement improves performance, because the program doesn’t change anything if it doesn’t need to."
Having to execute the IF statement seems as if it would take more time than just doing the task, without having to ask if the task needs doing.
Try it.
@DanielLench_ I found a way to minimize all of these touches prior to deployment.
- trusted location - can be defined in a custom install deployment
- support path - create an application plugin; the PackageContents.xml has the support path at a minimum and can include other things, like a custom CUI
- pipe catalog path - can be included in acad.lsp (or any LSP that initially loads for the application).
These are all true. The idea behind this post is to be able to take a
download directly from Autodesk and standardize the system as to not need a
deployment. This method works between versions so each year the upgrade
path for a company is already set. Thanks for the comments!!
True… In fact, the only thing I am doing in the “custom” install is just adding that single support path. Oh, and not including the Metric icon for C3D. :smiling_face_with_smiling_eyes:
lol, and I’m coming from a Linux background where everything is config
files :winking_face:
I figure the less I mess with the application, the better. I also want the
customization to be somewhat readable and able to do rolling updates from
CAD management standpoint. If the “config” files are solid and everyone is
locked into them, everything should work and be scalable.
