I was just about to add a markup to an RVT on BIM 360 Team (We just switched from A360 today) and the markup feature is gone. What gives? Was this a result of switching to BIM 360?
The markup tool just doesn't appear until the model has completely loaded. We have rather large models which tend to bog down Chrome (and often crash it) so you have to wait. It's just odd that the rest of the tools are there the whole time, while the markup button only appears at the end. Weird.
Hi Jarrod,
That is odd, i'll forward this on to our dev team to review and see if there is any reasoning for that to occur.
Have you tested other files and seen the same result as well, or just on the one model?
Let me know,
Other models do appear to load the markup tools last, but it's not very noticeable because they load so quickly.
Hi Jarrod,
so that we can test this on our end, would you please send me one of your files via public downloadable link?
Send to first.last@autodesk.com (brett.wright)
Hi Jarrod,
ok, here is what i found out for you 🙂
Please let me know if you're seeing something that we're not from our end where this is a bad way for the functionality to load.
No, it makes sense for it to function this way. I just didn't realize this was what was happening until after I created the first post. Then once I realized what was happening I added the follow-up.
My issue is that my MEP models are so heavy that stuff like this tends to happen. Architectural models of similar file size never seem to give me any problems. But this is obviously a different issue.
Thanks for the follow up Jarrod,
Let us know if you have any other questions / issues.
I'm having a similar problem,
I have shared the link, and they are not getting the mark up tools, comments tools or some of the navigation tools to the left.
is this normal?
Hi Robert,
Thanks for sending in your question.
When you share a public link, the comment and markup functionality aren't available since any member using that link isn't logged into A360.
It's always been like that, so if you do need your member to be able to have markup and comment functionality, then you'll want to invite them into the project vs just sharing the public link with them.
Let me know if you have any other questions.
@BrettWright Thanks for reminding me about this.
Awesome news Prathap,
Our customers will be very excited to see this come to fruition over time and it will really help the markup/commenting functionality be more seamless of an experience.
Keep us all posted on the progress.
I've read through the whole post and I still do not have mark-ups.
1. The project has completely loaded, it's a very small Revit project.
2. The project is closed
3. I am the administrator
4. None of my models have mark-up capabilities.
I've attached an image of my BIM 360 Team and what the video shows should be available.
Hi Lana, that is odd, these are RVT models correct?
Let me know, and yes, you should be seeing the markup icon in the toolbar as below.
I've been going through our jobs - there is no rhyme or reason if I get the markup or not. I opened an .nwd that was owned by someone else - there the markup is. I open an .nwd owned by me it's not there. Open another .nwd owned by me it's there. The same thing with. RVT's. How old the file is seems to have nothing to do if the markup is visible. Right now about 20% of the files have the markup. I am the administrator for BIM 360. Running out of place to troubleshoot.
The image (file) I shared - I tired reloading and it still did not have the markup. Yes, that is a very small .rvt.
I've opened BIM 360 Team in Chrome, IE, and FireFox, they all behaved in the same fashion.
I'll see if I can find a project that is not NDA to share the link privately.
hi Lana, we're looking into these now,
I did a quick test myself reloading them into my hub just to see if a "retranslation" might help, but no luck, I'm seeing the same behavior here.
Stay tuned, i'll get back to you once i hear back from the team.
Hi Lana, quick update, sorry for the delay here.
Hi Lana,
I heard back from the team, and the below might help you better understand what is causing the issue in your current file(s).
Please let us know if this helps.
___________________________
The exact error is that there is an invalid, invisible character in the property names prefixed with: JCPhase_
All those properties are:
We believe a possible workaround would be for those properties to be either removed or renamed from the seed file, and then re-upload the file.
There might be a –unit separator– (char code 31) symbol which is messing things up.
Note: There might be other properties with this issue. This one is the one I could find given the experienced error.
Thank you for the feedback.
While that might be causing some of issues, it doesn't explain the random nature of it working or not since all the files were created with our standard template that contains those parameters.
Hi Lana,
