When I have a Revit model with Revit left, and I put the RVT file BIM 360 team site, missing revit left. How can I do this so that everything will be placed on team site.
Solved by Bud_Schroeder_ADESK. Go to Solution.
Hi Perry,
Thanks for sending in your question to the team and welcome to the forum. It sounds like you are asking about linked models. You need to make sure that these models resolve to a single folder, then upload them as an assembly. Also be sure to select what file is the parent when uploaded the linked model. When you are in the browser, select "Assembly" as the option. Then browser to the folder with the files.
Hope this helps and have a great day.
