Revit links behaving Funny in bim 360 views
Hi i am having trouble with views in my shared BIM 360 files.
in the image below youll see that the links have been mirrored/copied, but in the revit file its not.
in the other project image the structural view copied itself and shaped into a sphere. looks crazy. but after logging on to another computer that resolved it self.
the site with linked model however looks the same even after re publishing.
mespaillat
Hi @Anonymous,
Thank you for posting to our forums.
This is strange behavior indeed. Is this reproducible across multiple web browsers?  Which/what browser were you using to take the screenshots? Can you reproduce the issue if you export the models as DWF/DWFx, and upload to BIM 36 team?
One tip that might prove useful is to open each model in Revit with the Audit check box ticked. If the audit returns with errors or warnings that apply to components of the model that are not displaying correctly in BIM 360 Team, please resolve them and save/synchronize your changes. Once resolved, try uploading to BIM 360 Team to see if the viewing issue is resolved.
If this response or recommendations prove helpful in resolving this issue, please click the ACCEPT AS SOLUTION button.
Thank you for choosing Autodesk Support.
Best regards,
mespaillat.
Autodesk Support Team.
Thank you for choosing Autodesk Support!
mespaillat
mespaillat
Hello @Anonymous,
I wanted to follow up with you on he Revit link behavior in BIM 360 3D views. Did you have a chance to review my response and suggestions?
If you found them helpful in resolving this issue, please click the ACCEPT AS SOLUTION button.
Best regards,
mespaillat.
mespaillat
mespaillat
Hello @design360,
I wanted to check in to ask if you had a chance to review my response and suggestions?
Best regards,
mespaillat.
mespaillat
