I can use a default image but cannot for some reason upload a project logo image.
Solved by nolangene. Go to Solution.
Hi Nolan,
That is not possible yet in Team.
See this prior post HERE, where another customer asked a similar question I believe that pertains to what you're wondering about as well.
Be sure to also add your commentary in the existing Idea Board link as well to show your support of getting this functionality.
Hi Nolan, so sorry for the confusion here.
Let me know if any of this helps you.
Nolan,
Can you please send us a screenshot of the error you see while uploading Project Avatar. Also please let us know the project name.
I select upload your own and then select the uploaded image 10NineLogo 100x100.jpg. When I click on update the blue line advances across the top and then the Choose Project Avatar just sits there. Click on update again and the blue line advances again. Have to click on cancel for the Choose Project Avatar to get it to close and the avatar is not updated. I am usually able to do this however the last two projects 42 Crested Cloud and Janga House would not allow me to set it on creation or through update as stated above.
Nolan Carl
Figured it out. While the image file was jpg and the system attempted to use it. It was a CMYK jpg. I converted it to a png (rgb) and it works fine. I would also assume that an jpg(rgb) would work as well.
