The measurement tool is missing. It just show up in the first 3 seconds while the file open and then it just disappear.
Do you have any explanation about this ?
thank you in advance.
Silvy Santosa
Hi Silva,
If you click on measuring tool icon, you can use it. Why this icon for measuring is disappearing in few seconds? I need measuring on Revit and Navisworks models. Our customers are always looking for measuring tool for Revit and Navis models. What should I tell them?
Hi Lukas,
Measure is only available in your 2D Sheets, and not the 3D views just yet.
In case you missed the prior post, i'll post it again here that explains the details best.
Let me know if you have other questions.
Hi Brett,
we upgraded our account from a trial version to the team version - how is it possible the team version has fewer functionalities?
Our designer we are cooperating with (not within our account) has the measure tool but we cannot check anything.
When will this be implemented?
Marcel
Hi Marcel,
Can you confirm what product your colleague is using here? If they're using BIM 360 Team, they'll have the same measurement capabilities as you do in your hub.
Regarding the ETA on what the 3D measure will be added into (for other than Fusion files), the development team doesn't have one published yet.
Dear BrettWright,
BIM 360 Team is amazing product compare to other collaboration software I would say. Both architect and Str. engineer appreciate the looks of the model inside BIM 360 team. Unfortunately, the measurement tools in 3D view are missing. Just 1 fact, a lot of people actually jump to other platforms like Tekla.
I would suggest that, Autodesk to quickly add in features like, measurement tools and spot elevations.
Thanks & Regards,
Kelvin
Hi Kelvin,
I agree with you, measurement tools in 3D view are mandatory for this kind of tool.
@BrettWright Do you know when this feature will be available ?
Thanks, best regards.
Fabian Perrée
Giùp.fr | LinkedIn
Ce post vous a été utile ? N'hésitez pas à aimer ce post.
Ce post a-t-il répondu à votre question ? Cliquez sur le bouton Accepter la solution.
Hi Kelvin and Fabian,
The best way to make sure our Dev Team know your thoughts around 3D Measure would be to add your comments here on the BIM 360 Idea board so that it can be added to the others that have posted on the same topic that already exist.
Thank you and have a great day 🙂
Hi Brett,
Will do !
Thanks and best regards.
Fabian Perrée
Giùp.fr | LinkedIn
