c4r trial not working
Hello , I have started a c4r trial ..but unable to collborate within revit after signing in it says "you currently do not have access to c4r"
below is the trial information from bim360 web login
Entitlements
This BIM 360 TEAM hub is on a 30-day Trial
61 days remaining
Your hub will be deactivated on Wed May 16 2018
Add-ins
Collaboration for Revit Trial for sa pk: 61 days remaining
sureshchotrani
Wellcome to the community:)
You may need to assign the same, kindly check the Autodesk Knowledge Network article
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
