I am new to the BIM 360 cloud working scenario. I have a rather large project consisting of REVIT files & DWG files that was originally on a server within the walls of the main office. We have moved all the folders/files onto BIM 360 Docs and are having success working with the REVIT files but are struggling with working with DWG files. What is the proper/suggested protocol for accessing and working with the DWG files?
Solved by mpetrucci. Go to Solution.
You can't edit DWG file in the cloud like you can with Revit Cloud Worksharing. One option is Autodesk Desktop Connector. The other option is Dropbox. The following is direct from Autodesk Support.
If the goal is to use Desktop Connector to enable collaboration in AutoCAD, the best workflow right now seems that it would be:
Hello Barry,
There is an update to mpetrucci's information. You can edit in the cloud after you have established an Autodesk connector process. I work in both Revit and DWG in the cloud, I was able to bridge and connect with consultants outside my network. The key to achieving this is having permissions in projects within your network and outside your network.
