what is the best workflow to transfer multiple cloud workshared models from one BIM360 account to another?
thanks
Solved by Chad-Smith. Go to Solution.
HI @echen4Q977 ,
There is not a workflow for BIM 360 you will either need to download and upload to the other project or look at Autodesk Construction Cloud Connect to automate the process. In Autodesk Construction Cloud it has Bridge which will allow you to transfer files from one project to the next but it is not available in BIM 360.
as @gareth.spencer1 mentionned, Bridge seems to be a quick way. BUT it will not be workshared files.
As the others have mentioned there are ways to transfer for storage.
But, if the intent is to continue working on the workshared models then the only way is to download and re-upload via Revit to set the new workshared location.
