Sorting in BIM 360 Docs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having issues with sorting the files in folders in the Plans area. I have uploaded a single pdf with multiple sheets. Extracts fine, has a Set assigned, each sheet has a custom attribute for discipline. Works great for filtering by Set (which, unfortunately is the only filter we got....) The custom attribute for discipline has a 00 number in front so that I can sort the sheets by discipline per NCS. Works great. BUT... when sorting this way it used to also keep the sorting of the sheet number so that A-101 was first, then A-102 etc. Well, that is not happening anymore. The sheet number sort is all over the place. Is anyone else noticing this weird behavior? It is very frustrating and my team who relies on the order to quickly find the sheets has stopped using the app... Such simple things can ruin its use.... I believe there are plenty of requests in the Ideas area for sorting and filtering capabilities for files in Docs. Please implement this ASAP.
