BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Revit Crashed While Working on a Revit Cloud Project and Now the Cloud Project Still Thinks the File is in Use.
8 REPLIES 8
Message 1 of 9
Darren|CM
797 Views, 8 Replies
While working on a Revit Cloud Project, Revit crashed.  Now when I try to open the Revit Cloud Project I get an error that says "Username is currently working on project.rvt" - Step I have tried to resolve the issue:
  • Restart the PC
  • Empty the %Temp% folder and restarted the PC
  • Empty the %LocalAppData% folder for Revit 2022 and restarted the PC
Any other suggestions?
8 REPLIES 8
Message 2 of 9
Yien_Chao
in reply to: Darren|CM
tried to logout your Revit session then login. if that don't works, you can still force relinquish through manage cloud models menu.
Message 3 of 9
Darren|CM
Unfortunately I don't have the "Relinquish" option in the Actions menu. Any other suggestions?Screenshot.png
Message 4 of 9
Yien_Chao
oh maybe you are not admin on the project?
other workaround : can you create a new central file and replace the existing one then?
Message 5 of 9
Darren|CM
in reply to: Yien_Chao
Yes I am an Admin.  The only workaround we have found is to download the file from the cloud, open in Revit, and then save again as a Revit Cloud Model. Of course - all cloud history is lost at that point which is not ideal.
Message 6 of 9
Yien_Chao
I don't understand why you cannot force relinquish then.
It is revit 2022 and ACC?
Message 7 of 9
Darren|CM
Yes Revit 2022 and ACC. It is very strange that the "Relinquish" option is not there.  Maybe that option is only available in the BIM Collaborate Pro subscription? I have checked all the settings in ACC and I have full admin access.
Message 8 of 9
jmollyhorn
AUTODESK  still haven't fixed this issue even after 3 years...
@jmollyhorn - this post has been edited due to Community Rules & Etiquette violation
Message 9 of 9
anthonymctigue
in reply to: jmollyhorn
There is a quick workaround for getting back into you cloud model after a crash on Autodesk's support site at the link below.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clear-a-corrupt-da...
