Parameters wrong type in NavisWorks - Bug
Renzo_van_Rijswijk
Renzo_van_Rijswijk
When I use ACC Model Coordination and open the views in NavisWorks. All parameters are set to text. This means that in your Find Items, you can not select a condition like > or <= for integers. Whereas they are set in Revit as Integer, and when you create a NavisWorks file directly from Revit, the parameters are Integers.
So, therefore we can not use this
Gr Renzo
filotkilot
Community Visitor
Community Visitor
Clash detection always runs under a format called clash matrix in which you decide how to perform clash jobs in short term which components you check if it intersect with other components for instance Hvac ducts vs Structural beams so basically the clash matrix is the most important paper in performing clash jobs. We have been doing so many projects using a software called Bexel manager. You can find all about clash detection inside a BIM environment in this course udemy https://19216801.onl/  https://routerlogin.uno/
