BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Old Records of Publish Log
7 REPLIES 7
Message 1 of 8
efratA6QBP
259 Views, 7 Replies
Hi there,
I frequently work with publish log records in a large project involving multiple Revit models (Version 2022). Our teams are publishing their models almost daily, and as a result, the publish logs I can access are mostly from the current or previous day.
The issue is that older records, even those from just a few days ago, seem to "disappear" as they are pushed down the list. If I need to retrieve a publish log from three days ago or last week, I can't find it anymore.
This has been an ongoing problem for me. Does anyone know how to access older publish log records?
7 REPLIES 7
Message 2 of 8
Not sure what the exact limit is in that view, but to see the rest you'll need to go to
Project Admin -> Sevices -> Document Management -> Activity
Message 3 of 8
Message 4 of 8
It might have more info than you want, but you could export the data to excel and try to filter the results.
Message 5 of 8
efratA6QBP
in reply to: efratA6QBP
Hi!
Thank you @Ryan_GormanKT36T for your reply, unfortunatly when I'm going to this tab I see a different screen than what you showed:
when I'm clicking on Document Managment, nothing happens.
Message 6 of 8
Are you an Admin?
Message 7 of 8
efratA6QBP
Partially. The project is located in the HUB of another company (not mine), and it has different administrators who have full control over different folders in the Document Management Module.
The publish log I am trying to access pertains to Revit model files in a folder that I have full control over. @Ryan_GormanKT36T
Message 8 of 8
efratA6QBP
But I am an admin.
