BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
New version of a reviewed file showing previous markups
2 REPLIES 2
pat.barrett7
250 Views, 2 Replies
We're setting up review workflows to cover the internal review process on a project. We're using the 1 step review process. Seems to be working fine except for one big issue, the mark ups from a previous version are coming out on the next version of the file. Not sure why anyone would want this but is there a way to turn this off without losing the original markup by archiving.
The steps we are looking at are:
  1. Upload pdf (version 1) & submit for review.
  2. Reviewer comments and markups the pdf through the review process.
  3. File is revised based on step 2 and new pdf version is created (version 2).
  4. New comments and markups are added or the file is approved.
Marking up a file normally (outside the review process) hides the markup on the new version but it can be checked if required.
Any help would be great.
2 REPLIES 2
pat.barrett7
in reply to: pat.barrett7
I'm not sure what you mean by clicking "no markup".
Is or was it a shared document and do you have unresolved conflicts in changes you and someone else made? I had a similar (but different so it might not be your problem) issue where I couldn’t turn tracking on until I resolved https://100001.onl/ https://1921681254.mx/  .
Technology Administrators
