More work with Docs so more to share.
Custom attributes are a good thing, I like functionality of date picker, whoever did it is a good man.
I was already dropping few lines on attributes limitations to delete them and too narrow band to manually adjust column width.
It can be more convenient if by double clicking on divider we can have columns to adjust the width to max length of the longest entry in the column.
also could be good to have decreased minimum width of the column. I.e. Currently it is minimum about 15 characters. But I have Rev. Column that uses 2-3 symbols so it is quite a waste of screen space to have it 15 characters wide. As a minimum should be auto distribution mode and manual customisation when I can set width for all columns and that will be remembered (per user).
Also need to be able to select position of the attributes, I.e. move attribute up or down on the list. I.e. I want to see revision and its date right after title of the drawing and to hide document name, file name, etc. Currently it is impossible.
