Latest Updates | New Knowledge Network Articles | BIM 360 Docs
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for BIM 360 Docs?
 Subscribe to receive updates for new BIM 360 Field Knowledge Network articles.
For additional updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
December 2017
BIM 360: “Page not found” error when trying to access the Account Admin page
BIM 360 Docs: Can folders be uploaded by drag and drop?
BIM 360 Docs: Creating a 2D file when Importing a 3D DWG file
BIM 360 Docs: Team member unable to access folders despite having the correct permissions
Revit Model 3D views are not accessible in Docs
November 2017
Apps & Integrations tab missing in BIM 360 account
BIM 360 Docs - Cannot download files on Safari Web Browser
BIM 360 Docs - Deleting older document versions
BIM 360 Docs - How to create a Title Block Template
BIM 360 Docs - Mobile app crashes on iOS device
BIM 360 Docs: Cannot edit attribute when using the search tool
BIM 360 Docs: Compare versions in color doesn’t work for RVT files
BIM 360 Docs: Error message displayed when trying to access a project: “The project is no longer ava...
BIM 360 Docs: Filtering by “Assigned to” does not work in the Issues module
BIM 360 Docs: Modifying Project Admin permissions locks member out
BIM 360 Docs: RVT 파일에 대해 Compare Versions 에서 칼라 비교 모드가 정상적으로 작동되지 않음
BIM 360 Docs: Unable to remove member from project, after previously deleting member in Enterprise A...
BIM 360 Docs: Uploading DWG Files without Layouts
BIM 360: Do Pending and Inactive users count against the number of licenses in use?
BIM 360: Virtual Reality & Augmented Reality compatibility with BIM 360 products
Docs - I can access projects in the web version, but not on a mobile device
Line color is difficult to see properly in BIM 360 Docs
October 2017
Account admin gets “not a member of BIM 360 project” after 30 days free trial expire for BIM 360 Doc...
BIM 360 Docs: Auto-generated Revit 2D sheets are in raster and not vector form
BIM 360 Docs: Cannot view element ID in walking mode
BIM 360 Docs: Model doesn’t display or keeps loading every time it is rotated
BIM 360 Docs: Moving drawings from Plans to Project Documentation area
BIM 360 Docs: Using the mouse wheel does not allow full zooming on drawings
BIM 360 products: Services are missing from the account
BIM 360: What are the URLs that should be used to connect to each of the products?
Why do the sheets in AutoCAD drawings get cropped when uploading to BIM 360 Docs?
BIM 360 Docs: Cannot access BIM 360 Docs: “The project is not active or you do not have access.”
BIM 360 Docs - Embedding pages and models into an external web page using iframe
September 2017
Activation Failed message is shown when trying to activate a BIM 360 service in Account Administrati...
BIM 360 Docs: “To manage permission on sub-folders, you must have a paid account” error message disp...
BIM 360 Docs: Not all sheets are updated with the new file version
Can we setup IP fencing for BIM 360 Docs?
Project data is missing with newly purchased BIM 360 license
How much storage comes with BIM 360 products?
BIM 360 - Single sign on error message is displayed when trying to contact support
BIM 360 Docs: “There was a problem setting up your project” error message displayed when accessing a...
August 2017
BIM 360 Docs: “View on document” button does not show in Issue
BIM 360 - Error message “Maximum number of users is reached” shows when you are below the number of ...
BIM 360 products: Can’t see the number of available seats on the Autodesk Accounts page
PDF opens to blank white screen in Internet Explorer when downloading from BIM 360 Docs
BIM 360 Docs: No email notification is received when an Issue status changes
BIM 360 Docs: Cannot download files with a comma in the file name
BIM 360 Docs: Inaccuracy in measurement for dwg and pdf
When importing animation from Vred to Maya framerate does not fit.
BIM 360 Docs - Cannot upload PDF files to Project Files Folder in Mozilla Firefox
BIM 360 Enterprise - Directly adding companies to projects
July 2017
BIM 360 - Newly bought services not showing in Enterprise Account
BIM 360 - Which Roles can Create and Add users to Projects
BIM 360 (HQ): After purchasing products I am not able to login on the administration page
BIM 360 (HQ): How to change my email address if I set up my account incorrectly
BIM 360 Docs - Cannot have multiple 2D & 3D Views files within the same folder
BIM 360 Docs - User cannot be added to projects
BIM 360 Docs & Plan - Licenses in Enterprise account on EU server unavailable
BIM 360 Docs (Mobile - Android): Why can’t I attach photos to existing issues?
BIM 360 Docs: Cannot open documents using the Android application on mobile devices
BIM 360 Docs: How can I have one of my accounts deactivated?
BIM 360 Docs: Self-extraction process when uploading Revit 2017 files to Plans results in changes to...
BIM 360 Docs: Why can’t I see my projects from the European server on the iPad app?
BIM 360 Docs: Why has my trial changed and I only have limited features of the product?
BIM 360: User without Autodesk Account cannot access project
June 2017
After changing email address in Autodesk Account, you are not able to access BIM 360 products.
BIM 360 (HQ): Unable to activate services for projects
BIM 360: Can users share licenses between accounts?
System requirements for Autodesk BIM 360 Docs
System requirements for BIM 360 products (Education)
BIM 360 Docs - Extracting 2D information from a 3D Revit model
Files uploaded into BIM 360 Docs show elements on sheets outside of Revit crop regions
BIM 360 Docs - Cannot download documents from project
BIM 360 Docs Minimap navigation does not work in Firefox
BIM 360 Docs: “Processing failed” message displayed when trying to upload a ZIP file
BIM 360 Docs: “Your account is not active” error message receive when trying to access the website
BIM 360 Docs: Invitations are not being sent, causing users to remain in Pending status
Markups in BIM360 Docs don’t work in Firefox
Access to the Apps & Integrations tab within the BIM 360 account has disappeared.
How to get support for the BIM 360 API web services
What are standards that can be used for moving BIM data into a preventative maintenance system?
BIM 360 Docs: Notification emails are not being sent to users mentioned in comments added to Issues
Is it possible to show multiple 3D views in BIM 360 Docs?
Matt DiMichele
