Failed Processing PDF File
carlosrdrzalns
carlosrdrzalns
Hi there,
I am getting an error in BIM 360 trying to process a pdf document, so it is saved to the cloud but I cannot open it in the viewer, as it has not been processed (translated to SVF).
The document's size is 11MB, could it be the problem?
Best regards,
gareth.spencer1
Hi @carlosrdrzalns ,
Where are you saving the file to? Is it the Plans area or the Project Files area?
Also is this a multi page PDF? As there is a page limit. See this article What are the size limitations when uploading a file to BIM 360 (NextGen)?
I would suggest reading this article also on the Autodesk Knowledge Network post "Processing failed" error appears after uploading a PDF to BIM 360  as it highlighted about Encrypted PDF files also.
I hope this helps you out.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
carlosrdrzalns
Thank you!! It is a multi-page PDF and it exceeds the Project File folder page limits, so there is the issue.
Best Regards,
