Design Collaboration permission levels
- Mute
- Permalink
- Report
We got some questions on the permission levels in Design Collaboration, and how they relate to the permissions on folders in Document management. In this post we want to give some background information what is happening behind the scenes when assigning permission levels to Design Collaboration users.
General
The user interface of Design Collaboration provides easy to use tools for share and consume workflows between multiple teams, while Document management folders and permission in the back-end are the basis, that enable these workflows. There's a separate post Set up teams and folders comfortably with Design Collaboration to get more background information on teams and folders.
Permission levels for Design Collaboration are assigned in the Design Collaboration Project Admin, and automatically grant the necessary permissions on various folders needed for publishing from Revit and sharing & consuming packages.
For Design Collaboration workflows there is no need to set extra folder permissions in Document Management itself, these can all be handled in a comfortable way through the Project Admin user interface.
Steps to define permission levels
- Access Project Admin
- Under services, select Design Collaboration on panel on the left
- Select Team
- Manage Team members
- Adjust permissions per user, role or company
Design Collaboration Permission levels
View only
Users can view the team’s Work in Progress data (WIP) like published sets, the project model, packages visible to the team.
Adds viewing permission to
- global Shared folder
- team folder
View + edit
Users can publish from Revit into team’s WIP folder, create and update team’s packages. Can consume packages from other teams.
Adds edit permission to
- team folder
View + edit + share
Users can share packages with other teams.
- team folder
- team’s Shared folder
Custom
Permissions have been defined in BIM 360 Document Management and don’t match the categories above.
Inherited
A member has access to a parent folder of the team folder, e.g. "Project Files". In this case the access rights can't be changed.
Note: A project administrator role will be mapped to a “View + edit + share” permission level.
Markus Briglmeir, Product Manager BIM 360 Design Collaboration
