Hi Andrew,
The BIM 360 Docs team is working on a number of usability and functionality enhancements, and I understand and appreciate your input about attributes.
I have a question about your expectations. When can an attribute (which is inherited in subfolders) be deleted? If there is simply an attribute added at the folder level, but no attributes have been entered for the documents, it is very straightforward. However, what do you think should happen in these cases?
1) There is an attribute defined at the folder level and there are attribute values associated with some or all documents in the folder.
2) There is an attribute defined at the folder level (which is inherited in the subfolders), and there are attribute values associated with some or all documents in one or more subfolders.
Do you agree that Docs should pop up a warning and allow deletion (after confirmation)?
Should you be able to restore deleted attributes (and their values)?
Thanks in advance for your input.
Best Regards,
Joan Allen
Sr. Product Manager, BIM 360 Docs
