DataSource.Error: No data requests for this project in the last 30 days. Users with project admin access can request data from Autodesk Data Connector.
bim.bot
bim.bot
I want to get the project extracts data using Autodesk Construction Cloud as shown in the following picture -
here is the project extract option to get project-related data as follow - bimbot_1-1687267680564.png
I would be able to extract account-related data but Unfortunately getting the error mentioned below -
Please let me know if something is not clear..
stirado69N8G
Community Visitor
Community Visitor
Hola soy Carlos Ortega, tengo una licencia de Power BI y tengo exactamente el mismo error que estan presentando, podrian apoyar con alguna solución por favor.
cameron_wallaceTCPTR
Community Visitor
Community Visitor
I asked help desk:
This error message appears because you have not run the Data Connector extraction report for your Project or Account, depending on the hierarchy you are using. Once the extraction report is successfully completed, you should no longer see this error message, and multiple schemas should become visible
Please refer to the attached link:
https://help.autodesk.com/view/DOCS/ENU/?guid=Data_Connector
It can guide you through the process of running the Data Connector extraction and setting up a schedule so you can refresh the data.
