Create one private file/ folder for client in BIM 360 Docs?
Hi
Is is possible to create a file or folder within in project file, that is visible only to select team members? Other members would not receive notification of uploads to this folder. ( I just need to upload large files for the client's information only).
Thank you
mespaillat
Hello Karen,
Than you for posting to our forums. I believe you were recently assisted by my colleague Thomas on this issue, and wanted to circle back with you in this thread in case it helps other users that have the same question.
"BIM 360 Services do offer restricted user access. I believe this link with show you how to work with folders and more specifically, manage folder permissions:
https://knowledge.autodesk.com/support/bim-360-docs/learn-explore/caas/CloudHelp/cloudhelp/ENU/BIM-3...
Be sure to look at /use the menu on the left side of center panel for more how-to knowledge links."
If the response provided by my colleague was useful in answering your inquiry, please click he ACCEPT SOLUTION button.
Thank you for choosing Autodesk.
Regards.
mespaillat.
Autodesk Support Team
Thank you for choosing Autodesk Support!
mespaillat
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @mespaillat provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Nathan_Reasons
Hello, the link in the solution appears to be broken, do you have an update for this?
