Coordination models within Revit not visible
willem.creffierKCWFB
Hi there,
I have Revit View with a .nwd model linked as a "coordination model.".
When I open the view in the BIM 360 Environment, the Linked Model Is not visible.
Is there a way to get it going through?
Is there another way to merge a view with a .nwd file?
Kind regards,
Willem
Hi @kenechivora ,
within revit, the .nwd Coordination model is Visible.
It is only when I open this view in the Bim 360 interface, that it disappears....
It would be nice to acces the Intelligence from Navisworks Selection sets in this environment.
Kind regards,
Willem
Yien_Chao
where is the nwd link? on you pc or office server? it wont works
you will need to make a copy of the nwd in bim360, relink from there to your Revit, then publish again to Bim360 (with the link visible in view of course)
Hi @Yien_Chao ,
yes, I hosted the .nwd file in bim 360.
I have views where it is visible, others not.
But the .nwd model does not appear.
I tested another computer without firewall....Nope.
Can you visualize the .nwd model?
Kind regards,
Willem
Yien_Chao
did you try to publish nwd from Naviswork?
Yien_Chao
my bad, you are right. we cannot view the nwd link in bim360 no matter how we proceed. now that's an odd.
