Connector message: Value cannot be null Parameter name: path
This is the message I see in the connector,  files seem to be  stuck, connector not synching. I found a possible solution to edit the backup and restore settings but are unable to find the installation of the Vault Server.
Could there be another cause ?
With kind regards,
Rik
Luciane_Conceicao
Autodesk Support
Autodesk Support
Hi Rik,
Thanks for your post.
Could you please explain your workflow and possibly the steps to reproduce the error message?
Looks like there is an issue with the file path. Where are the files located?
Are they long paths?
Cheers,
Luciane
Luciane Conceição Taylor
Product Support Specialist
Autodesk, Inc.
Please click the button "Accept Solution" if this suggestion resolves your issue.
Luciane_Conceicao
Autodesk Support
Autodesk Support
I have found this article that seems related:
Error: Value cannot be null. Parameter name: Path
Does it help?
Cheers,
Luciane
Luciane_Conceicao
Autodesk Support
Autodesk Support
Hi Rik,
I wanted to see if you need further assistance with this matter.
Cheers,
Luciane
Autodesk, Inc.
