Change default project
silviu.bunu
silviu.bunu
Hello, community,
I have a situation that I have been facing for some time and I do not know if there is a solution. Please tell me, if possible and if so, how I can make sure that when I open Revit I can manually set the first project, the one in the blue circle, without having to select that one project every time I open Revit? (see the picture in attachment).
Thank you in advance for your support.
múinteoir
The behavior should be that the most recent project will shown by default, and the remaining projects in the list are in alphanumeric order, making it easier to find the right project. Not sure that a default project can be defined.
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
nolangene
Clarity here is the problem. Default would imply one project being set as the project that you will ALWAYS open first. Not sure that is helpful here or wanted. But that is what you would get. By most recent he means the last project that you had open will be the project that should show. That alas is not always the case. Recently behavior has changed in this area. Also as to the listing it has been getting messy and out of order recently. To me this means someone in the backend is working on this. Unfortunately patience is called for. I have been getting the upper most project in our project list LOL and that is the hub template. So hang in there they are working on this entire system.
mcoxQ4S2V
Well, it doesn't.  That is not the behavior that I see each day.  It is aggravating.  I am always taken to the last project that we created and that I was added to within the company.  Even though I am working on a different project every day.
jurquhartRUQR2
Community Visitor
Community Visitor
I also have an issue with this, and it is annoying, when is this expected to be fixed?
