Can I download the 2D sheet drawing from the Revit file?
I'm trying to figure out a way to download the Sheet drawing from the BIM360 cloud.  I search online someone said it's able to download in the Plan folder but our BIM360 does not contain a plan folder........(Please see the attachment)
Or.... Is there a way I can export sheet drawing from multiple revit files at the same time?
DemiHan
Hi @Anonymous,
Thanks for contacting us. From the snapshot, yes, looks like you need to contact your project admin to provide your access to Plans folder.
Bing
mespaillat
Hello @Anonymous,
I wanted to follow up with you to confirm if the response provided by @DemiHan to contact your project admin was helpful in resolving this issue?
If so, please click the ACCEPT SOLUTION button so that it may help other community members with the same issue in the future.
Thank you for choosing Autodesk Support!
mespaillat
Autodesk Support Team
mespaillat
mespaillat
Hello @Anonymous
I wanted to know if our responses were helpful in resolving this issue?
mespaillat
mespaillat
