Does BIM 360 have integration with Oracle Aconex? We have a project that is running through Aconex, but the client wants to use Field Management and Document Management for the review workflow. Is there any way we could facilitate the transfer of files from BIM 360 to Aconex, and vice versa?
Solved by gareth.spencer1. Go to Solution.
Not that im arare of, maybe possible with Connect https://apps.autodesk.com/BIM360/en/Detail/Index?id=7330054718304792786&appLang=en&os=Web&autostart=...
Or i did see this https://www.bimlauncher.com/bim360-acc-aconex-integration which seems to offer the service of connecting them
Hi @marianne.lima yes you can integrate aconex with BIM 360 using
Hi @BassantNabilOmar / @marianne.lima ,
Sorry but Autodesk ACC Connect does not currently support the link between Autodesk Construction Cloud or BIM 360 and Oracle Aconex at the time of writing this post. Here is a list of the current app integrations.
Hi @gareth.spencer1
Autodesk team already did it for a construction company using ACC Connect. They created a customized recipe to make l live connection between aconex account and ACC account
I agree with @gareth.spencer1 that ACC Connect won't natively do this, and will require specialist consultation services.
Word on the street is that Agave will be able to do this soon.
Hi @Chad-Smith
I am talking based on an existing case, a client we are working with bought ACC connect and Autodesk made this connection for them. That is why i back to @gareth.spencer1 to confirm that is already done. That is it.
BIMLauncher offers a ready made solution to connect Aconex and Autodesk Construction Cloud/ BIM 360.
A direct link to the app on the Autodesk App Store can be found below, along with a link to the BIMLauncher website:
Correct, there are several ways to get this done. 1) Through ACC Connect recipies 2) Partners such as BIMLauncher.
Hope this helps.
Correct, there are several ways to get this done. 1) Through ACC Connect recipies 2) Partners such as BIMLauncher. Hope this helps.
