Autodesk Docs / Revit 2023
paulmonsef
paulmonsef
I downloaded Revit 2023, and the Desktop Connector update. But for some reason my Projects do not show in Revit 2023 (still works in 2022).
Not sure if this is a Doc's issue, or Revit. Anyone else having the same problem?
Paul Monsef
http://monsefdesign.com/
Yien_Chao
that's normal. you have to update you entire files to 2023 before.
Chad-Smith
The BIM 360 project is locked to the file format of the project's first uploaded Revit model.
The upgrade process occurs on the BIM 360 project. Check out the following link. At the time of writing this, it doesn't look like BIM 360 has been updated to allow a 2023 upgrade.
Upgrade Cloud Models | Revit 2020 | Autodesk Knowledge Network
paulmonsef
That makes sense. Thanks!
there is probably a post like this every year. Haha.
Paul Monsef
rebeccadavidson
We are having the problem that we can't even see the folders to initiate collaboration in a brand new cloud project in 2022. Any ideas?
Tim_Nix
We're having similar problems with not being able to see folders (through web or Revit), anyone figure out what's happening? Seems like something changed in the last couple weeks maybe?
