BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Autodesk Construction Cloud - Bridge Outgoing and incoming items not able to removed from list?
14 REPLIES 14
Message 1 of 15
Wentao_Guo
1518 Views, 14 Replies
Hi, all
I'm try to figure out how do I remove items from outgoing and incoming item list. I have removed Bridge between project and deleted folder shared by other party, however it's still shown under list. I'm not sure how can I remove them?
Refer Image from ACC help page as example...
14 REPLIES 14
Message 2 of 15
roy_peryea
in reply to: Wentao_Guo
Hi Wentao, it is currently not possible to alter (or remove) items found in the Incoming our Outgoing tabs for Bridge. This is intentional as it is meant to provide an audit trail for our customers.
Could you help us understand why you would like to remove items from this list? How do you leverage the Incoming and Outgoing tabs today in your job?
Roy Peryea
Senior Product Manager
Message 3 of 15
Wentao_Guo
for example. Some shared folder like this
Message 4 of 15
Wentao_Guo
in reply to: roy_peryea
Hi Roy,
refer image I replied above, our company just start explore Bridge function with other consultants and contractors, some mistake has been made during process, for example "untiled" bridge, "titled" bridge with incorrect folder shared, vice versa, it has been made some of BIM coordinators confused with current list,  therefore, an "archive" function or somehow allow to clean the list would be handy.
Thanks.
Message 5 of 15
roy_peryea
Hi Wentao,
Thank you for the feedback. This is a feature request that I will note for our team.
So that I can better understand your user needs, how are you currently using the Incoming and Outgoing tabs of Bridge? It sounds like you're using it as the primary way to locate the shared content (files, folders, sheets), rather than trying to find the content via the Files or Sheet tool. Is that right?
Do you always look at the Incoming and Outgoing tabs to find your Bridged content? Or only when there is a problem or confusion?
Roy Peryea
Message 6 of 15
Wentao_Guo
Hi, Roy,
At moment we are only use Bridge to automate revit file sharing process with our contractors as we are not fully utilize Built function yet. Idea is no one need spend more time on traditional workflow of revit file share, incase you are not familiar Australia market, I will explain more...
There are a lot of companies share/transmit file via Aconex, which means every week BIM Coordinator need clean up file and upload them it to Aconex, manually send them out to 3rd party, similarly downloading 3rd party files from Aconex and relink them back into revit, that's a lot of repetitive manual work and a lot of time has been wasted.
I'm glad that with combination of scheduled model publish in Design Collaboration module and Bridge module, we can achieve automation of weekly sharing model without human intervention.
Come down to bridge list, it is more for BIM Coordinator to have clear list to figure out which and what come in and out in a simple form, I was imagen it should acting as index? but if information is not clear, and unable to adjust, then will defeat purpose of "index".
I hope my explain are clear.
Message 7 of 15
roy_peryea
Hi Wentao,
Yes, that all makes sense. Thank you for the additional context!
Roy Peryea
Message 8 of 15
Wentao_Guo
Hi, Roy,
Thank you for proactive follow up. I already can see the platform will improve in near future.
Message 9 of 15
tnievesP53K8
This is still a new feature and most of us are testing this out and not always getting it correct. (it's not very intuitive). Thus I now have several "Untitled" bridges in my projects that were part of a test before actually doing it with the real thing. I guess these will have to live there and confuse staff?
I see the previous comments about this were over a year old and still nothing.... It is growing tiring seeing Autodesk implement new features but not accounting for the fact people test them before fully rolling them out. This same thing happened when we tried testing out parameter service and then couldn't permanently delete the parameters. Autodesk had to go into our account to refresh everything. If your worried about "Auditing" simply have the admin of the other company "approve" the deletion.
Tags (1)
Message 10 of 15
https://forums.autodesk.com/t5/acc-ideas/bridge-link-removal/idi-p/13002224
seems this idea has been accepted and is likely on the roadmap. i am also waiting for this option to be a thing.
Message 11 of 15
roy_peryea
Hi @curtisridenour ,
The other Forum post that you referenced appears to be discussing the need to hide (or delete) external, bridged Design Collaboration Teams from within the Design Collaboration timeline.
The ability to hide/archive/delete rows within the Incoming and Outgoing tables of the Bridge tool is unfortunately not something that is currently on the Bridge team's one year roadmap, although I can see why some folks would want to hide some rows if they make errors when testing out Bridge. Generally speaking, I don't think we would ever want to allow users to truly delete any of these entries as one of our main principles is to keep a record of content that has been shared into/out of a project using Bridge. I could see us allowing Admins to filter these out somehow though (e.g., archiving them similar to archiving files in Docs, or saving filters). However, priorities can shift around. I would be interested to hear more about your needs in this case and how you use the incoming/outgoing tables as well if you'd like to share.
Roy Peryea
Message 12 of 15
curtisridenour
hmm. Well, this sounds a lot like how Issues cannot be permanently deleted. I see where you are coming from. But I disagree with not letting the Admin have those kind of privileges.
I am new to using bridge and some of the nuance of the tool still escapes me. I do not like having every mistake i make along my path of becoming proficient being visible to all users within the project. I don't want them confused with 6 files in the list of legitimate bridged folders as @Wentao_Guo showed above.
Message 13 of 15
BIMdalorian
That is stupid. There needs to be at least a way to archive or deactivate them.
Message 14 of 15
peterhRHQJV
Create a preview screen of what we're going to see/what's going to happen if the concern is "audit trails", etc before creating this permanent part of the project with no undo button
Message 15 of 15
ArniVidar
Any updates on this? I'm working on the Bridge for the first time, and have made some mistakes / decisions were changed. That I can neither undo those mistakes, or simply fix the folder selection in the bridge is frankly ridiculous, and now everyone working on the project will see this nonsense for years to come.
Honestly, I don't buy that "there needs to be a history" argument. I don't know what sort of state secrets y'all are working on over there, but we just need to be able to get some data between projects (temporarily and/or permanently) and be able to CHANGE the settings after it's been made, for example when sub-folders are added. Nobody cares about the history. The histories are on the original projects. Everybody cares about things 1.) Working correctly, and 2.) Being up to date. That's all.
This feels like an overly complicated way to build a bridge between two projects, when you have to create a folder automation every time something new is added or changed or moved, and the system builds countless pages of old and unused shares.
Please at a minimum add an Archiving option ASAP, if not an outright option to modify the share after it's been made.  :slightly_smiling_face:
