ACC Build - Can Submittals have custom field or location tag added to them?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
This might be an Ideas post too.
The project we are setting up is horizontal and broken out into bridges and work package names/numbers.
We will be having submittals come in that reference different work packages. I might be missing something, but the submittals do not let you add a custom field or a location tag.
Will custom fields be added or location tags?
Currently, we are using the workaround of spec sections referencing the work package number so that this is a dropdown for the sub-contractor to select.
Does anyone else have this issue or a better workaround? I would appreciate hearing yours.
I appreciate any help you can provide.
Mirra
