Hi All,
Apologies, I assume this issue has come up before but I will ask the question anyway as I can't find a specific answer by searching the forum.
We have recently bought BIM 360 Docs to deliver a BIM Level 2 project, we are aware of it's limitations and will write any work-around information into our BIM Execution Plan.
My question is with regard to variable information such as Suitability Status and Revision Numbers which are required to comply with PAS1192. We understand this is one of the above mentioned limitations and my understanding is as follows: Docs uses the title block information to define whether the drawing is a new version or new document therefore if we add the "variable"suitability code/revision status to the drawing title when a revision is uploaded the 360 Docs reads a different title and uploads as a new document.
I had assumed that the file name was the controlling factor, which would make more sense. If the file name was the same surely this would be the defining factor in whether the document was a new version or new document.
As I can gather this leaves us with the following options:
1. Ignore the suitability status code and revision number on the drawing sheet when defining the drawing template and add the Suitability Status/Revision to the file name as the file name doesn't define the version. This may carry with it compliance issues but may be a work-around and may be less susceptible to human error.
2. Alternatively we add 2 drop down menus for the suitability status and revision however this could be open to manual error if the drop down choices don't match the drawing sheet. It could also be subject to unauthorised change.
Ideally an option to add additional fields when defining a title block would solve this issue. These would have to be a variable field type to avoid the issues as mentioned above. If a fix is in the pipeline, I think it is important that this is something that can be added manually, including the title of the field or of it is a pre-set field there should be more than one i.e. revision and suitability status.
Having said the above, to my knowledge this can only be said of pdf drawings, if a model were uploaded there is no facility to capture a suitability code or revision automatically therefore drop down menus would be the only option in its current form.
I'm sure this will be a key issue for many UK adopters.
Any feedback or correction on this matter would be welcome.
