Hi Gareth, thank you for the response. My terminology might not be exactly correct, I'll try to explain it more clearly.
We have a Revit model saved in the Autodesk cloud (I believe the cloud hosting is called 'BIM Collaborate').
I would like for certain users to be able to open the model in revit on their local machine, and view/measure/print, but not SYNC. There seems to be only 2 levels of permission in the 'Roles' tab of BIM Collaborate, the 'little blue man' symbol which means the user cannot even get to the file through Revit and 'the yellow gear' symbol which means full edit ability.
When I attempt to use 'Revit Viewer Mode' it throws the following warning at me 3x, but then it opens the model and does what I'm looking for. Just wish there was a 'right' way to do this without user getting these warnings.
This warning also suggests 'editing a detached copy' which is a ridiculously overly-complicated endeavor with cloud hosted Revit models compared to central models hosted on-prem.
If you have any other suggestions, I'm open to investigating. Thanks again!
My other CAD is a Cadillac and I like to Revit to the Max!
