Set a Default Value to an Attribute
ian.mangelsdorf3ZLFY
Does anyone know how to set a default value to a custom attribute??
gareth.spencer1
Hi @ian.mangelsdorf3ZLFY ,
Are you talking about the attributes in BIM 360 /ACC Docs? If so you cannot edit the out the box attributes, but you can switch them off and create custom attributes which can be either a text field, drop-down list, or date.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
Hey Gareth  thanks for the reply,
Using ACC at the moment,  I am fine with creating and editing etc.  Bu I am trying to set an attribute value to a default value when a new document is created
gareth.spencer1
It is not something that you can set to do automatically I am afraid. If you apply the naming standard when you set up a review process you can add auto increment on the status. I would suggest you put this forward as an idea in the BIM360 Ideas forum.
Gareth Spencer
