.SCR Script file support in BIM360
Hello, I'm 1/2 way through my 1st day using BIM360 and have run into a question I can't readily find the answer to.
For plotting, we load a script file (.scr) to call certain lisp routines from common standard file paths on user's machines. These lisp routines update titleblock attributes and a few other tasks. Then plot the PDF's to a standard output folder.
I have uploaded one of these .scr files to BIM360, but the interface tells me that .scr files are not supported. The file still shows up in FileExplorer, but not when you view the BIM360 folder online. The file is not tracked with version history. However, the file is still editable and can be called to run from in Autocad,
I know the un-supported file list shows .scr, but is listed as Windows Screen Saver.
So my question is, can AutoCAD script files (.scr) be stored and used on BIM360? If not is there a work-around?
I'd like to keep the projects setup/resource files managed fully on BIM360 rather than relying on users to copy extra files locally. Which defeats the purpose of document control.
C3D2020 / C3D2021
Desktop Connector ver. 15.2.0.1634
