Revit file uploads - Processing failed
avi.singhal
avi.singhal
I've been trying to upload Revit Project file ( Revit 2013 file) but it failed to Process. Please advice. Image attached.
Best Regards,
Avi
markus_briglmeir
Hi Avi,
Thanks for reaching out.
I'd like to ask you to contact product support, and log a support case under Using my Product.  All required information to investigate your issue will be collected through that approach. This will be more efficient compared to using this public forum.
If you haven't done so, please re-try an upload to make sure the issue wasn't caused by a temporary effect on the connection or the backend systems.
Thanks again for posting here,
best regards,
Markus
Markus Briglmeir, Product Manager BIM 360 Design Collaboration
avi.singhal
Thank you for your response. Will follow as advised.
