Publishing Scan projects greater than 100 scans
jason_schwartz
jason_schwartz
We have successfully published scan projects with ~100 scans.  Projects over 100 scans say they published successfully, but return "Sorry, Can't load project" and "Sorry, No rch file is found" errors."  All RCH files are present and we have the correct permissions.   We have tried this same project, but selected 75, 98, and 150 scans.  The 150 scan publish fails the same way as the full project (540 scans).  We can only guess that this is a limit to the number of scans that can be successfully published and then viewed on BIM360.  Can anyone confirm this or share a work around?
ben.mckay
Yea I'm getting the "Cant load project" but haven't seen the other error you posted. We have about 50 scans in the project and I have admin level permissions on the folder.
jason_schwartz
Just give it a few days and it sort itself out. We are posting 500+ scan
projects now. Still get the error for the first few days.
Bramdf
We have experienced the same problem. When we want to publish 120+ scans, the "publish indicator" continues to run and never stops.
Do you have the same issue during the publish?
