Project Template is Missing (new project setup)
dgt.mantis
dgt.mantis
I have setup a BIM 360 template with the folder structure I want.  However, whenever I make a new project and I go to "Services" and "Design Collaboration" or "Document Management" I cannot find the template.
I have confirmed that the template is using the same language and I even put them in the same time zone, but it does not show on the list.
ChitnisPrateek
I have tested the workflow and its works on my end.
Please follow the process in this link to check if it works!
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Template-projects-...
One of the steps it mentions in the above link is that when you created the template project, try choosing the project type as Demonstration project.
If this solution works for you, please accept it as a solution so that others can find it as well. Thank you.
Thank you.
Prateek Chitnis
BIM Manager | AECO (Buildings)
Did you find this post helpful? Feel free to click on the Like button.
