[ON-DEMAND WEBINAR] Running Projects from the Cloud with Autodesk Docs
anna.luisa.monteiro
Autodesk Autodesk
Message 1 of 1
anna.luisa.monteiro
Autodesk Docs supports AEC teams with a centralized document and data management solution that helps streamline communication, improve transparency, and maintain project momentum from design through construction and turnover. It acts as a centralized source of reference, helping project stakeholders work from the most current and reliable information. 🚀
Through built-in connections with Autodesk’s design authoring tools such as Revit, Civil 3D, and AutoCAD, and compatibility with a broad third-party ecosystem, Autodesk Docs facilitates a more integrated workflows across the project lifecycle. As a common data environment (CDE), it supports access to critical project information by the right people at the right time—whether in the office, on site, or in between.
You can’t expect better outcomes by working the way you did yesterday. To support meaningful improvements in project delivery, teams need connected, modern workflows that promote clarity, accountability, and efficiency across the lifecycle.
Join our Technical Specialists as they walk through real-world workflows that demonstrate how Autodesk Docs contributes to more streamlined project delivery. Whether you're in the office or out in the field, Autodesk Docs helps keep teams connected, coordinated, and informed.
This webinar is ideal for all project stakeholders—Owners, Project Managers, BIM/VDC Managers, Design Technology Leaders, and field teams—who are looking to improve efficiency, foster accountability, and support better outcomes across every phase of a project. We’ll cover how to:
  • Organize and manage design, construction, and owner data in one location
  • Access files via web browser anytime, from virtually anywhere
  • Enhance collaboration through Autodesk’s integrated solutions and broad ecosystem
  • Promote data continuity and accessibility through a secure, cloud-based common data environment
  • Enhance project quality and efficiency with issue management, version control, and standardized workflows
  • Work offline and in the field on any mobile device
👉Register here
Replies (0)
